Elastix-2.0.3-x86_64-bin-15nov2010.iso on VPS
rscl.mumbai
I have an IBM X3200 M3 Server.
I have installed CentOS 5.6 Final 64bit OS as the host OS.
I have installed VirtualBox 4.0.4
I am now installing Elastix-2.0.3-x86_64-bin-15nov2010.iso as a new VM.
When I start installation, I see the Elastix Welcome screen, I type -> linux text.
After a couple of messages the screen hangs (see attached).
What could I be doing wrong ??
Pls let me know if any additional system info is required.
Thx
Vai http://forum.elastix.org/old_files/Screenshot-20110414.zip
Update:
I tried installing Elastix-2.0.3-i386-bin-15Nov2010 CD and it worked like a charm.
What is required to install the 64 bit version ?
Pls help.
Thx
Re:Elastix-2.0.3-x86_64-bin-15nov2010.iso on VPS:
Solved the issue!
It was a setting in VirtualBox which was incorrect.
MEGAN SULLIVAN
