elastix 2.4 two issues with voicemail
witekprytek
Hi All;
I have noticed two issues with voicemail on elastix 2.4 could somebody confirm it or help to resolve the issue.
1. The voicemail generally work, but when I set "Play Envelope" for the voicemail extension system creates two files for each message with the same name and extension .wav and .WAV e.g. msg0003.WAV and msg0003.
When i try to listen message using standard voicemail code (*98), system plays envelope and then disconnects.
When i Delete in the voicemail folder all files with .WAV i can hear the stored messages.
2. On the fresh installed system -system does not create any folders in /var/spool/asterisk/voicemail/default when i try to add voicemail to the extension. Only broken symbolic link is created in /var/spool/asterisk/voicemail/device -to non existing folder in the ./default folder
When I create the files manually and change the files permissions all working fine, but I can not do this from the elastix or freepbx gui.
Apollo Cloud
