Elastix on VPS (Need Help)
adeel2cool
I am newbie and just install Elastix on VPS server, in network parameters there is no Ethernet card & mac address showing, but when i go in system-config-network there is vnet0 please see the attached pic.
need help can't able to connect softphone xlite gives error 408. I think this is the reason.
Please son one can help :dry:
Thanks a lot http://forum.elastix.org/old_files/dasbord_pic.zip
It works perfectly on IAX protocol. I found out my ISP Blocked SIP protocol, is it possible to bypass SIP protocol by changing default ports on Elastix?
Thanks for help.
Use port= directive in trunk description to specify SIP port of your trunk;
Use bindport= directive in sip.conf (or sip_general_additional.conf) to specify Asterisk listen port;
Use rtpstart= and rtpend= in rtp.conf to specify RTP ports range.
Thanks for your help I will try.
definitely try and let you know.
Thanks for the help :lol:
kanderson
