Enabling the Callback Unsuccessful Blind Transfer Feature NOT WORKING
toptech1
I created a dial code for
Unsuccessful Blind Transfer​
*2
I dialed this code to activate it but it tells me NO ACTION PREFORMED any advice? maybe I'm doing it wrong?
Are you talking about the Dial Code under Settings --> General?
If yes, maybe consider changing the "*2" as that overlaps with the default dial codes found in Settings --> Dial Codes.
I'd suggest using what's in the example: *3*
Yes I changed it to *3* and dialed that code still says NO ACTION PERFORMED
my question is if I have to dial this once into the system or everytime I transfer
No, you actually don't need to dial it at all. The transfer back on busy should now just work if you perform a Blind transfer to a busy extension.
estrezacafe111
