- Joined
- Apr 30, 2021
- Messages
- 1
- Reaction score
- 0
Ok, this has me scratching my head, and all help greatly appreciated.
Summary
Every time an outbound call is made, the call fails with an error of:
Cause: 604 Does not exist anywhere
Details
New 3CX setup, running on a Raspberry Pi, setup as a Generic VoIP Trunk with provider Westnet (their config settings). Westnet is owned by iiNet, and uses the same infrastructure, despite different domain names for the services.
Registration of the trunk is successful, and I can make calls between extensions successfully, as well as receive calls successfully.
However, whenever I go to make an outbound call and regardless of the number dialled, I get this persistent error:
From looking at the logs, the outbound rule seems to be correctly set, and it's attempting to make the call with the right trunk, but I can't establish why the 604 error is happening, and no amount of searching has led me to a solution thusfar.
Outbound call rule configuration
Apply this rule to these calls: Calls from extension group(s), DEFAULT
Make outbound calls on:
Relevant logs
Summary
Details
- Route 1: Westnet, Strip Digits 0, Prepend left blank, Outbound caller ID set to public phone number for the VOiP trunk
- All routes beyond this set to BLOCK CALLS
Relevant logs
30/04/2021 23:16:49 - Leg L:3.1[Extn:10] is terminated: Cause: BYE from PBX 30/04/2021 23:16:49 - Leg L:3.2[Line:10000>>1300786068] is terminated: Cause: 604 Does not exist anywhere/INVITE from 203.59.49.10:5060 30/04/2021 23:16:49 - [CM503020]: Call(C:3): Normal call termination. Call originator: Extn:10. Reason: Not found 30/04/2021 23:16:49 - L:3.1[Extn:10] failed to reach Line:10000>>1300786068, reason Not Found 30/04/2021 23:16:49 - Call to T:Line:10000>>1300786068@[Dev:sip:[email protected]:5060] from L:3.1[Extn:10] failed, cause: Cause: 604 Does not exist anywhere/INVITE from 203.59.49.10:5060 30/04/2021 23:16:49 - [CM503003]: Call(C:3): Call to <sip:[email protected]:5060> has failed; Cause: 604 Does not exist anywhere/INVITE from 203.59.49.10:5060 30/04/2021 23:16:49 - [CM503025]: Call(C:3): Calling T:Line:10000>>1300786068@[Dev:sip:[email protected]:5060] for L:3.1[Extn:10] 30/04/2021 23:16:48 - [CM503027]: Call(C:3): From: Extn:10 ("Michael XXXXX" <sip:10@XXXXXXXXXXXX:0>) to T:Line:10000>>1300786068@[Dev:sip:[email protected]:5060] 30/04/2021 23:16:48 - [CM503004]: Call(C:3): Route 1: from L:3.1[Extn:10] to T:Line:10000>>1300786068@[Dev:sip:[email protected]:5060] 30/04/2021 23:16:48 - Line limit check: Current # of calls for line Lc:10000(@Westnet[<sip:[email protected]:5060/UDP>]) is 0; limit is 2 30/04/2021 23:16:48 - Call(C:3): Call from Extn:10 to 1300786068 matches outbound rule 'Default: Westnet' 30/04/2021 23:16:48 - [Flow] Call(C:3): has built target endpoint: Out#:>>Rule{Default: Westnet}>>1300786068 for call from L:3.1[Extn:10] 30/04/2021 23:16:48 - [Flow] Target endpoint for 1300786068 is Out#:>>Rule{Default: Westnet}>>1300786068 30/04/2021 23:16:48 - [CM503010]: Call(C:3): Making route(s) from Extn:10 to <sip:1300786068@XXXXXXXXXXXX:0/UDP>
