Error installing on amazon aws - configuring firewall
angelo1
Trial User
I'm using the 3CX certificates but the installation gives up on the last step, when Configuring Firewall.
I've tried creating it multiple times, the EC instance is running, but the installation never finished.
Why can I do?
angelo
Hey @angelo1
Judging by the error you're getting it seems the PBX was unreachable on it's https port when the installation was closing to an end.
That said, what I recommend you check first, is the firewall rule on AWS. Just go to the AWS EC2 Console, select your region from up-top, open "Security Groiups" under "Network & Security", edit the "pbxexpress" security group and check the rules for https.
• Make sure that you have 2 HTTPS rules for port 443 (IPv6 and IPv4)
• Make sure you have 2 TCP rules for port 5001 (IPv6 and IPv4)
Yes, both rules exist, for both version of ip:
Hi @ChrisC_3CX ,
Did you have time to review this? it looks like a problem on the script that creates the EC2 image.
angelo
Hey @angelo1
We cannot replicate this on our end so what i recommend you try is delete any and all security policies with name "pbxexpress". And try to redeploy. The required security policy will be auto-generated and should work out of the box
Let me know how it goes
Hey @angelo1
I've removed all the security policies previously created by the automated deployment and after do it agin, I get the same error
LeeonLau
