Extension and Voicemail DIDs
prairie
We have a user that when we receive a call, send it to the extension and the user does not pick up, the call goes to voice mail. When a call comes in from someone using that same user's DID, it never goes to voicemail. Any ideas?
couple of things to check.
The extension 'following rules' are set to same for internal and external calls.
Is the DDI number going direct to the extension and not using a ring group , using different routing
To be clear, the person calling in is originating the call from a device sending the same caller ID as the DID number they are dialling?
Check the 3CX Activity Log (compare a working an non-working call). It should show where the non-working call ends up, and possibly why.
Herm77
