Solved Extensions in MGMT console are red but phones are registered
Alphabetic
3CX MVP
16.0.8.9
Supported templates
Local install
VM Debian 8GB RAM 50GB HDD 8 CPU
All the phones on the LAN are registered and are making/receiving calls. However, the extensions in the mgmt console show as red.
I've rebooted services and the VM.
Phone Firmware update ?
Yealink T40G - 76.84.0.95
@kieferschild
Since the extensions are making/receiving calls, it seems to merely be a presentation issue, otherwise, if the 3CX PBX had considered them as unregistered, the calls towards them would route to the extensions forwarding rule "If I am busy or my phone is unregistered, forward calls to:"
That said, could you try loading the Management Console from Google Chrome in incognito mode with no browser extensions enabled? Do you get the same thing?
@kieferschild
Ive actually reinstalled the PBX since posting (other issue and not cracking a nut with a sledgehammer)
Reactions: ChrisC_3CX
Great! As long as it got sorted!
devo.it
