Extensions remain online even when the phone is turned off
tiagodemedeiros
Forum User
Intermediate Cert.
Good Morning.
We have a question to be analyzed:
Extensions registered on a softphone remain online in the 3cx system even with the phone turned off.
Does that person have a 3CX on mobile phone? Those are always registered.
Yes, but the status remains online even with the phone turned off :rolleyes:
Then my question is: is it normal to remain registered or how long does the extension remain registered after turning off the cell phone?
7 days from the last time the app was opened. I don't know if you can deregister it manually beside adding another account in the app and switch to it.
Registration time explained.
I've tried to manually unregister but I can't find where to do it. I also tried to register another account on the softphone, but the previous registration remains on the system.
Then you will need to wait. In the meantime, use the statuses (like DND) to force the call to go to Voicemail.
Reactions: tiagodemedeiros
It seems is still unclear how this push notification works:
i'ts not the softphone client the one who registers to the PBX - there is a push service on the PBX installation which "impersonates" the softphone client, SIP registering on its behalf to the PBX.
Apart from this, its major functionality is to send to the global, worldwide push server (Apple for iOS, Google for Android) a payload everytime it receives an incoming call and an end call as for the client it impersonates. Mainly, the payload contains device identifier, caller id, caller name and a call identifier. Then, those global servers communicates with their operating systems (iOS for Apple, Android for Google) on client's device based on the device identifier. The operating system then starts the client process (or wakes it up if not running) then passes it the caller id, caller name and call identifier, so the client can call back the caller - very, very similar with the known *20*.
So, I hope I've explained pretty clear why the extension remains registered even if the softphone client is powered of - because it's not the client who SIP registers to the PBX, but it's the push service.
If you want the extension to become unregistered, then the client should unsubscribe from push to the PBX - this will instruct the aforementioned push service to unregister. Depending on the version of the client and the PBX, this is done from client's Forwarding Profiles, "allow push notifications".
Hope it's clear.
Hope it's clear.
Excellent explanation, I also had this doubt.
Mahlon
