Extensions Status
coreybrett81
I wish the Extensions table in the admin console had a "Status" column.
Also, when changing an extension's status, there is no UI feedback that the change was accepted.
Ther's no dedicated column for status.
You need to check manually in console, or follow with webclient
travislogixal
