Solved External Siemens Gigaset C470IP authorization Issue
Volkan Celebi
I did configured in our office all of Yealink phones. Everything works good but I can't set the correct settings for C470IP. I am filling the forms of web interface of phone but I see always Registration failed error both on phone screen and 3cx log
here is log:
Code:
11/08/2018 12:28:20 PM - [CM102001]: Authentication failed for AuthFail Recv Req REGISTER from 192.168.44.33:5060 tid=a9971b799f9ce70af86d771ac73fcc4 Call-ID=3778725326@192_168_33_44: REGISTER sip:sip01.xxx.com SIP/2.0 Via: SIP/2.0/UDP 192.168.44.33:5060;branch=z9hG4bKa9971b799f9ce70af86d771ac73fcc4;rport=5060 Max-Forwards: 70 Contact: <sip:[email protected]:5060> To: <sip:[email protected]> From: <sip:[email protected]>;tag=1024642584 Call-ID: 3778725326@192_168_33_44 CSeq: 21 REGISTER Expires: 180 Allow: INVITE, ACK, CANCEL, BYE, OPTIONS, INFO, REFER, SUBSCRIBE, NOTIFY Proxy-Authorization: Digest username="haydar",realm="3CXPhoneSystem",algorithm=MD5,uri="sip:sip01.xxx.com",nonce="414d535c11f4aed482:e31c7ccab03cd2e896ca84d6de25ece5",response="7e655298bca50baed34ae5cbbffb802b" User-Agent: C470 IP/022270000000 Content-Length: 0 ; Reason: Credentials don't match, check that authorization-ID and password match the ones in extension settings
problem fixed.
Reactions: YiannisH_3CX
Roman Mazur
