Fail with Microsoft365 integration
TTelecom
I need some help, our customer have a 64SC Enterprise edition in the last version and with all the updates installed and no other kind of third party app nor integration
We triedt to make the Microsoft Integration to import customer's users and contacts from their Microsoft 365 Bussiness Standard.
We followed all the steps from https://www.3cx.es/docs/manual/microsoft-365/ but we cant go beyond Point 5/Step 3 (Login with Microsoft Azure admin account from 3CX Admin Console and give the permissions needed to the app).
After that a new Login With Microsoft 365 button is shown in the 3cx login page, but after filling the credentials in the microfsoft login page it redirects again to the Admin Console login
When we try to sync, the 'Add Users' button is greyed:
Here is the 3cx's log when trying to login with microsoft credentials:
Code:
2022/11/23 08:36:24.630|7410|0108|Trc|[Microsoft.AspNetCore.Hosting.Diagnostics] Request starting HTTP/1.1 GET http://exaplePBX.3cx.es:443/signin/microsoft?jwt=false - -
2022/11/23 08:36:24.630|7410|0108|Dbg|#18883 (traceid=0HMM7PV8LUJE5:00000023) START: GET https://exaplePBX.3cx.es:443/signin/microsoft
2022/11/23 08:36:24.630|7410|0108|Trc|[Microsoft.AspNetCore.Authentication.OpenIdConnect.OpenIdConnectHandler] oidc was not authenticated. Failure message: Not authenticated
2022/11/23 08:36:24.630|7410|0108|Trc|[Microsoft.AspNetCore.Authorization.DefaultAuthorizationService] Authorization failed. These requirements were not met:
2022/11/23 08:36:24.631|7410|0108|Trc|[Microsoft.AspNetCore.Authentication.OpenIdConnect.OpenIdConnectHandler] AuthenticationScheme: oidc was challenged.
2022/11/23 08:36:24.631|7410|0108|Dbg|#18883 (traceid=0HMM7PV8LUJE5:00000023) STOP: GET https://exaplePBX.3cx.es:443/signin/microsoft processed 00:00:00.0011602
2022/11/23 08:36:24.631|7410|0108|Trc|[Microsoft.AspNetCore.Hosting.Diagnostics] Request finished HTTP/1.1 GET http://exaplePBX.3cx.es:443/signin/microsoft?jwt=false - - - 302 0 - 1.3133ms
Tried to attach the detailed log after restarting services but it has moren than 1000 chars, so I uploaded to pastebin, the domain is anonymized to demo.3cx.es
https://pastebin.com/fXGqJLBS
Hope somebody can help me
What have you set for the graph permissions?
Does you're match these?
Reactions: Hasso97
yes, that is the set of permissions:
Reactions: Hasso97 and jed
here are a blog of the log file, regarding 365 authentication
Code:
/var/lib/3cxpbx/Instance1/Data/Logs/3cxManagementConsole.log:2022/12/02 08:59:08.714|7522|0069|Trc|[Microsoft.AspNetCore.Hosting.Diagnostics] Request starting HTTP/1.1 GET http://customer.my3cx.es:443/api/office365 - -
/var/lib/3cxpbx/Instance1/Data/Logs/3cxManagementConsole.log:2022/12/02 08:59:08.714|7522|0069|Dbg|#47737 (traceid=0HMMDEJAF2O2G:0000000E) START: GET https://customer.my3cx.es:443/api/office365
/var/lib/3cxpbx/Instance1/Data/Logs/3cxManagementConsole.log:2022/12/02 08:59:08.714|7522|0026|Trc|[Microsoft.AspNetCore.Hosting.Diagnostics] Request starting HTTP/1.1 POST http://customer.my3cx.es:443/api/settings/TeamsIntegration application/json;charset=utf-8 2
/var/lib/3cxpbx/Instance1/Data/Logs/3cxManagementConsole.log:2022/12/02 08:59:08.714|7522|0026|Trc|[Microsoft.AspNetCore.Cors.Infrastructure.CorsMiddleware] No CORS policy found for the specified request.
/var/lib/3cxpbx/Instance1/Data/Logs/3cxManagementConsole.log:2022/12/02 08:59:08.721|7522|0069|Trc|[Microsoft.AspNetCore.Authorization.DefaultAuthorizationService] Authorization failed. These requirements were not met:
/var/lib/3cxpbx/Instance1/Data/Logs/3cxManagementConsole.log:2022/12/02 08:59:08.721|7522|0069|Trc|[Microsoft.AspNetCore.Authentication.Cookies.CookieAuthenticationHandler] AuthenticationScheme: Cookies was forbidden.
/var/lib/3cxpbx/Instance1/Data/Logs/3cxManagementConsole.log:2022/12/02 08:59:08.721|7522|0069|Dbg|#47737 (traceid=0HMMDEJAF2O2G:0000000E) STOP: GET https://customer.my3cx.es:443/api/office365 processed 00:00:00.0069024
/var/lib/3cxpbx/Instance1/Data/Logs/3cxManagementConsole.log:2022/12/02 08:59:08.721|7522|0069|Trc|[Microsoft.AspNetCore.Hosting.Diagnostics] Request finished HTTP/1.1 GET http://customer.my3cx.es:443/api/office365 - - - 403 0 - 7.1058ms
/var/lib/3cxpbx/Instance1/Data/Logs/3cxManagementConsole.log:2022/12/02 08:59:08.721|7522|0026|Trc|[Microsoft.AspNetCore.Authorization.DefaultAuthorizationService] Authorization was successful.
/var/lib/3cxpbx/Instance1/Data/Logs/3cxManagementConsole.log:2022/12/02 08:59:08.721|7522|0026|Trc|[Microsoft.AspNetCore.Routing.EndpointMiddleware] Executing endpoint 'ManagementConsoleJS.Controllers.SettingsController.TeamsIntegration (3CXManagementConsole)'
/var/lib/3cxpbx/Instance1/Data/Logs/3cxManagementConsole.log:2022/12/02 08:59:08.721|7522|0026|Trc|[Microsoft.AspNetCore.Mvc.Infrastructure.ControllerActionInvoker] Route matched with {action = "TeamsIntegration", controller = "Settings"}. Executing controller action with signature System.Object TeamsIntegration() on controller ManagementConsoleJS.Controllers.SettingsController (3CXManagementConsole).
Code:
Did you check the app registration permissions as per my previous reply? as yours are set incorrectly, as per the screenshot you provided.
Check them carefully.
Reactions: jed
I'm awaiting for the customer to re-create the permissions.
I followed the guide in a test instance and was able to sync without problems so for sure the problem is because the delegated permissions
Thank you!
Thank you!
It's for sure the permissions!
Reactions: jed
