Failed Authentication Protection Blacklists after three failed login attempts, but the configuration is set to 25....
MrG.
Forum User
I have the "Configure the amount of failed authentications that 3CX Phone System will accept. If this value is exceeded the source IP address is put in the Blacklist" set to the default 25, however, ip addresses are getting blacklisted after every third attempt. I've searched through the forums and did not see a similar issue. Our version is: 15.5.15502, and our system is locally hosted. Any thoughts?
What/how is user authenticating/logging into?
into the web client portal. It's not a show stopper because I can just wipe out the IP, but it's annoying. Perhaps I do not understand the setting....?
I believe 3 is the maximum limit for the management console/web client and this cannot be changed. the anti-hack is for SIP auth attempts and the like.
Ahh... I sort of figured I was misunderstanding the setting, thank you for that.
I suppose I could just whitelist the IP's...
Personally I wouldnt. I'd get them to "remember me" in their browser instead or use a credential manager such as Dashlane.
Reactions: MrG.
yeah - I get it. Thank you for the advice.
bosdorf
