Fanvil DTMF ISSUE
Farkhad1597
hello
i have fanvil x5u but dtmf is not working on it. could you please help me with that? what setting should i check ?
Firmware version?
How are you provisioned?
Version of the 3CX PBX?
Firmware version?
Firmware version is 2.4.12, i provisioned via provisioning link, and 3cx version is 16
You should upgrade to v18. A lot of DTMF improvements were made in the new version.
Reactions: JohnS_3CX
@Farkhad1597 DTMF issues can be caused by multiple factors, it's not necessarily the phones fault.
Does DTMF work when you call 3CX voicemail and type your PIN ?
As a start, you should consider upgrading to V18 and seeing if the problems go away.
dominik.pepel
