Fanvil H2U Autodial
gbrown100
Hi everyone,
Just looking to see if anyone has used these at all? I am looking for a solution where a mobile food truck that has internet access can pick up a phone and immediately be put through to an IVR that gives them two options. The rest of the site is 3CX so nice and easy. Does anyone know if you can program the H2U to autodial upon pickup? I realise this won't be part of the template!
Failing that I guess I could configure it's solitary DSS key to go to the menu instead but there are lots of buttons to accidentally press and some very sticky fingers!
Graham
I just wanted to add, there are 2-3 spots if you just look for the word hotline - the one you want is under SIP config.
Teemal
