Fanvil i60k
Elliot Cater
Does anyone know if the Fanvil i60k will work as a door entry system with our 3cx system and what template should be used for this?
It would be great if we could get the door releasing a Magbolt and the video stream to be viewable through the 3cx web interface.
https://www.fanvil.com/products/p5/i6 series high-end video door phone/20241009/9141.html
It's a decent looking unit and at a really good price point so would be great to get this working.
Many thanks!
Even if it does work, it does not look like it is supported which can lead to all kinds of issues (even if you get it working as the next update might break it).
I am using the Fanvil i30, the i16SV, and of course the newer i61, i62, i63 on multiple installations - have not used the i64 that looks more like the one you want.
They are all outside getting wet and abused by the temperature changes without any issues. And I use the relays too in all of them to open doors and of course video.
LeeonLau
