Fanvil V Pro Series
kent3
Do we know if the V Pro series will be 3CX approved soon? I have a client that is keen on a wireless handset setup (not DECT) didn't want to go down the Yealink route as thats a bit out of his budget and we mainly use Fanvil.
Will the V62 template work on a V62 pro? Anyone tested or similar?
I know I'm using the v65 template for the new V66 Pro phone successfully. I started another thread last week asking about the v66 template as well. =)
Reactions: kent3
Nice one. Thanks for the info!!
I will say I can't assign a PNP-detected phone to an extension, the option is greyed out. I can only manually assign to an extension, but then it works fine.
Reactions: kent3
Thanks for the heads up, so you are using + Phone in the Users/IP Phone tab? As long as its properly provisioned, that works for me. :)
Correct, just added IP hone under the user extension using the MAC address. Factory reset the Fanvil and it comes right up.
Reactions: kent3
Using the V65 template, only the first nine BLF's appear on the phone.
i got the same thing. Provisioning works like butter, but only the first 9 BLF works.
can we manually change the config file to get more BLF's to work?
Diogo Maia
