Fanvil X4g
BenN123
I am having an issue with the fanvil phones that they dont pick up the correct vlan using cdp unless i log into the phone and under advanced network settings and check off vlan on the wan port and put the vlan id into the field. If i plug a yealink into the same switchport it configure with the correct vlan.
I factory reset the phone and loaded the latest firmware. Is there some setting i need to set on the switch ? These are hp procurve but i have cdp turned on and running.20240212_201212 (1).jpg
Could you please capture the packets on the switch where the issue occurred? I would like to examine the packets for a more in-depth analysis.
