Solved Feature for limit time for calls
fquiroz
Hi, Im new in 3cx, I need a feature in outbound calls limit a specific time value for example local calls limit dutarios for 10 minutes, it is possible in 3cx actual version???
There is no function like this within 3CX
You could write a service, leveraging the 3CX Call Control API, to monitor all (or select) calls and when the call duration reaches the specified length drop the call. You could even have an automated message play something like "Your call will be disconnected in 30 seconds". For that matter, you could assign a budget for each extension and drop the call when their budget has been exhausted. Yes, this is possible with some custom code.
There is a maximum call duration in 3CX and is 3 hours for security purposes. But you cannot different calls with different durations. Perhaps this is something you can from your provider side though.
Thanks for your help, Saqqara, VoIPTools, YiannisH_3CX.
I am migrate a Voip Solution of my client, for 3CX, my client have define routes in actual system with time limit for each type calls, 10 minutes for locals, 15 minutes for celular, etc.. Adicional he have routes with authorization codes for calls for example celular, international, etc.. Both features in 3CX, are not avaliables, is possible in road map maybe in the new releases can includes???
@fquiroz as this is a very unique request there will be little to change to find this on a roadmap of 3CX.
As @VoIPTools mentioned you might utilize a partner to write you a custom integration.
ICTSupport@bedfordgirlssc
