Feature Request – Customisable SP Key Labels with Shared Presence
adam.wells@leadersystems.
Platinum Partner
Hi team,
We have received a feature request from one of our customers and have been asked to submit on their behalf.
"I’m writing to enquire whether it’s possible to submit a feature request through Leader Systems’ 3CX partner portal on my behalf, as my current partner level does not allow me to raise ideas for future improvements directly.
I have a medical practice that requires the ability to customise the names displayed on the SP (Shared Parking) keys on handsets. At present, there is no option within the 3CX Management Console to rename these keys. While it is technically possible to change the labels via the handset web interface, 3CX automatically reapplies the default button layout during its nightly provisioning, which overrides any manual changes.
3CX support has advised that the only alternative is to configure custom speed dials for call parking and call pickup (https://www.3cx.com/docs/pbx-dial-codes/). However, this solution does not provide shared presence information on the keys. For this particular site, shared presence on the Park buttons is essential, so custom speed dials are not a suitable workaround.
Given the number of medical and multi-room environments where clear labelling of park keys is important, the ability to customise SP key labels within the Management Console while retaining shared presence would be a valuable enhancement."
Thank you.
Kind regards,
Upvote 6
You should be able to achieve this by using a custom phone template; you will probably have to reserve specific BLF numbers for the SPs, and hardcode the names inside the template.
Finatra.us
