Feature request - Custom time setting for Override office hours
Simnet
Hi, regarding the override office hours, it appears that only predefined time intervals can be selected. Currently, the available options in 3CX are 15 minutes, 30 minutes, 1 hour, 2 hours, and 12 hours and etc. However, we often receive requests for custom durations, such as 3, 4, or 5 hours which are not currently supported.
It would be greatly appreciated if a feature could be added to allow custom time ranges, similar to what’s available in FortiVoice PBX and other systems.
Thank you.
Hi @Simnet
As a workaround, go to Integrations >> Call Scripts >> click Add from store >> add the scripts to put departments in or out of office, and configure a dial code for it.
Then you can edit the code to specify how long the PBX will be set to out of office.
Also, each script has a link with an explanation on how it works and how to use it.
ARKC
