Feature Request - Grandstream GXW42xx extension tab - import from csv / xml
jasontaylor85
Feature Request - GXW42xx extension tab - import from csv / xml
Hello, this is my first post in community although I feel I know my way around a 3CX quite well now after more than a few different installations.
Currently when setting up GXW42xx using 3CX FXS/Dect template I have to manually drop down each box / port and select the relevent extension number which can be very time consuming if you have several 48 port devices to set up (I had x7 of these on one install). Also port number is not shown, so for example if I want to make sure ext 2050 is on port 30 I have to count each line carefully otherwise everything above this may be out by 1 port.
It would be much easier to import this information from a .csv or xml spreadsheet.
Sorry I'm unable to post this under Ideas - You have insufficient privileges to post threads here.
3K8iMGWviZ
