- Joined
- Jan 27, 2019
- Messages
- 56
- Reaction score
- 3
Hi All,
I am having trouble getting a 3CX install to pass the firewall tests.
This is a snippet showing the fails:
As you can see, we are having to use non standard ports due to the ISP blocking 5060 and 5090.
I have had this working with a 3CX setup at home, using those ports, and it is all fine, but here I am getting the above fails.
I have checked that the ports are forwarding correctly, by connecting from outside (internet) using telnet, and it works fine to connect to both 55060 and 55090. Just to be 100% sure, I also did a telnet test from within the LAN, and that works fine too.
Can anyone suggest a further test I can perform to narrow down what is happening, or where to look from here?
Thanks in advance,
Alan.
- testing 3CX SIP Server... failed (How to resolve?)
- stopping service... done
- detecting SIP ALG... not detected
- testing port 55060... full cone test failed (How to resolve?)
- starting service... done
- testing 3CX Tunneling Proxy... failed (How to resolve?)
- testing port 55090... full cone test failed (How to resolve?)
- testing 3CX Media Server... failed (How to resolve?)
- testing ports [9000..9398]... failed (How to resolve?)
- testing port 9000... full cone test failed (How to resolve?)
Thanks in advance,
Alan.
