Solved Firmware update Snom 715 after V18
saba
hi
i m expeting a firmware issu after upgrading on V18 with snom 715 phone
i saw this tread https://www.3cx.com/community/threads/firmware-and-provisioning-problem-snom-715.86243/
when i apply the update, the phone reboot and start downloading but stuck at 2%
  • 3CX Version, 18.0 (Build 314)
  • Server OS, Windows Server 2016
  • Is the 3CX Server Hosted and where? . On-premises
  • IP Phone Make/Model/Firmware version, snom 715 version 10.1.73.16
  • Provisioning Method: Local
  • Trunk Provider or VoIP Gateway Make/Model,
  • Are custom Phone Templates being used: NO ?
Thanks for ideas
ok manually it works
if found the issue, phones are in a vlan which have no access to internet. they are provisionned with 3cx ip address and not FQDN but in the phone the FW upgrade link point on the FQDN so it fail...
ok fixed thanks for the advice !
Reactions: ChrisC_3CX
Glad to see you got this sorted!
Feel free to start a new thread should anything else come up!
