Firmware Update
MartijnDoeland
Forum User
Since the last service pack the option install a custom firmware in the Yealink no longer functions.
Choosing the standard firmware works however. The Lydis option doesn't.
is this enabled for you?
Yes. See image
I have the same problem over here. Default yealink firmware works, but the Lydis one doesn't push to the phone.
To install/upgrade to the LYDIS firmware of a Yealink phone, the phone must already have a version of LYDIS firmware on it.
This means that you cannot from 3CX go from Yealink Firmware to LYDIS firmware. The initial switch must be done by your LYDIS distributor first. What this does allow you though is to maintain you LYDIS firmware up-to-date from the Management Console.
Before someone assumes something, I also want to say that it is Yealink that does not allow the switch from regular Yealink firmware to LYDIS. If you check the Yealink logs when you try to do so, you will see yourself as the log message does stand out.
OK, thanks to my supplier who told me to upgrade all my phones, none have the original Lydis firmware anymore.
Herm77
