First time configuration of 3CX
KaterinaK_3CX
This guide covers all you need to know when configuring 3CX On Premise for the first time. It includes information about the Configuration Wizard, the FQDN, DNS and Ports.
Read the Guide.
I received an error while deploying 3CX on Debian
https://www.3cx.com/docs/manual/configuring-your-pbx/
After selecting Static IP on the step 4 :
Select your default local network interface from the list of network adapters below:
/usr/sbin/3CXWizard : ligne 65 : 9215 Erreur de segmentation sudo -u phonesystem /usr/lib/3cxpbx/PbxConfigTool
Removed /etc/systemd/system/multi-user.target.wants/3CXPhoneSystemMC01.service.
Removed /etc/systemd/system/multi-user.target.wants/3CXEventNotificationManager.service.
Removed /etc/systemd/system/multi-user.target.wants/3CXCfgServ01.service.
Removed /etc/systemd/system/multi-user.target.wants/3CXMediaServer.service.
Removed /etc/systemd/system/multi-user.target.wants/3CXIVR01.service.
Removed /etc/systemd/system/multi-user.target.wants/3CXTunnel01.service.
Removed /etc/systemd/system/multi-user.target.wants/3CXHotelModule01.service.
Removed /etc/systemd/system/multi-user.target.wants/3CXPhoneSystem01.service.
Removed /etc/systemd/system/multi-user.target.wants/3CXQueueManager01.service.
Removed /etc/systemd/system/multi-user.target.wants/3CXSystemService01.service.
Removed /etc/systemd/system/multi-user.target.wants/3CXAudioProvider01.service.
Removed /etc/systemd/system/3CXPhoneSystemMC01.service.
Removed /etc/systemd/system/3CXEventNotificationManager.service.
Removed /etc/systemd/system/3CXCfgServ01.service.
Removed /etc/systemd/system/3CXMediaServer.service.
Removed /etc/systemd/system/3CXIVR01.service.
Removed /etc/systemd/system/3CXTunnel01.service.
Removed /etc/systemd/system/3CXHotelModule01.service.
Removed /etc/systemd/system/3CXPhoneSystem01.service.
Removed /etc/systemd/system/3CXQueueManager01.service.
Removed /etc/systemd/system/3CXSystemService01.service.
Removed /etc/systemd/system/3CXAudioProvider01.service.
active
dpkg: erreur de traitement du paquet 3cxpbx (--configure) :
le sous-processus script post-installation installé a retourné une erreur de sortie d'état 139
Des erreurs ont été rencontrées pendant l'exécution :
3cxpbx
E: Sub-process /usr/bin/dpkg returned an error code (1)
Any help would be apreciated.
Buenas Tardes, En el primer paso si por algún motivo se cierra o cambiamos de TTY y perdemos el configurador antes de definir instalación por web config / Linea de comando podemos reabrirlo de la siguiente manera
cd /usr/lib/3cxpbx
./PbxConfigTool
y asi tenemos de nuevo el configurador. Saludos!....
Good afternoon, I have a contribution for you if it disappears for some reason or change the console and lose the configuration tool
This can be reopened from
cd /usr/lib/3cxpbx
./PbxConfigTool
this is how it reopens and allows us to define the configuration method of 3cxPbx
And apologies for my bad English.
