FOP -Problem
topher
I am using Elastix 2.4.0 with 5 trunklines using AE1610E OpenVox card. I noticed and always encoutered the voice response "all circuit are busy now, please try your call later" aside on that the FOP was sometimes blinking in red. Is there any configuration need to add on this new version?
Regards...
how did you set up your trunks? you need to give us more details to help you out?
what is the color of those modules on your AE1610E? Red for FXO, green for FXS, if you are connecting to PSTN, the modules should be in RED color as you have to use FXO.
have you setup the trunk and outbound routes correctly? have you check out the system --> hardware detector?
try to run asterisk -rvvv in cli mode for debugging. after run asterisk -rvvv, make some calls, you will see how the call process step by step. it might help.
eokwaro
