Fop2 -how to install - addon or sources?
witekprytek
Hi;
I have new machine running with elastix. On the old one I have installed, using sources, FOP2. Everything in such a configuration had worked perfectly for me.
In new elasix version I can install fop2 using addons section.
I have made the test installation using addons. I have also installed freepbx addon for managing FOP2.
I'm not able to configure FOP2 - ussers buttons in the way I want (for example - I do not see que buttons or trunk buttons). The fop2 configuration files in elastix distro are located in different places than described in fop2 manuals.
When I use "addon" version of FOP2 - I'm not able to log in directly to the FOP2 panel with full screen. To access FOP2 I have to login to the Elastix Gui first.
Is there any docs where can I find some description of FOP2 integrated in elastix - how to configure it, where to find configuration files etc.?
Is it possible to get direct FOP2 acces without login to the elastix?
Maybe better way is to install FOP2 from sources and configure it manually?
Apollo Cloud
