Forward All?
J_Hermsen
I'm looking for some option to add a speed dial to forward all inbound calls.
For example Grandstream has an option to set 2 modes on the inbound rules which can be switched by a calling a code.
Is some thing like that possible with the 3cx system?
Thanks for the tip, but that's per extension.
We would like to add a speed dial button to redirect any incoming call on any line/number to be forwarded.
Hello @code6
The system has a dial code to force the system to either in office hours or out of office hours which will also affect the call destination if set up correctly.
Please note that if you use these dial codes to force the system out of office hours you need to use the dial codes to force the system back to defaults or office hours will be ignored .
If you set the dial code to *64 for example then *640 will be default office hours, *641 will be in office hours and *642 will be out of office hours
Oke Thanks that sounds more like what I need.
Glad i could assist
Or setup office hrs, and get the system automatically make the switch
Herm77
