Solved forward extension to more than one phone
proboscis
Hi all, I'm trying to set up a new v16 installation and could use some help. Our current Avaya system has a coverage path that allows one manager's phone (A) to ring. If (A) doesn't pick up, the call goes to their assistant (B). If (B) doesn't pick up, it goes to another assistant (C). Then back to (A)'s voicemail. I can only seem to find to allow forwarding to one extension in the forwarding rules of the extension, not more than one. Any idea if this would be possible? Thanks.
Go to the forwarding rules of EXT A and configure the time out options. Then do the same for B and C.
12868
Reactions: proboscis
Otherwise, create a ring group with ring strat prioritized hunt with PA 1 and PA 2 in that order.
EXT 1 > forward to RG > Try PA 1 > Try PA 2 > Destination no answer > VM of EXT 1
  • Haha
Reactions: proboscis and AWS2P
Why not using a RG with A,B,C in prioritez hunt mode and DNA set to A VM
you rock! That's what I needed exactly. thanks!
Reactions: YiannisH_3CX
Kayla Norris
