- Joined
- Aug 23, 2021
- Messages
- 12
- Reaction score
- 2
I have a DID that we forward to the call center for the most part permanently. i dont want when anyone calls it to ring on our phones, it should go straight to the call center operators. outgoing works fine and shows the caller id of that DID properly.
i have incoming for that DID to forward to an external number and the number to the call center put in. for both office and after hours. however it still wants to ring on the main extension.
so if I go to that main extension and in the forwarding rules change it to 1 second for ring time and put forward to external number and the call center it then will work. but the main extension rings one time then sends it to the call center.
I dont want that main extension to ring at all. how do i make it so the DID is permanently forwarded to the call center number?
thx much
thx much
