FQDN and IP name stuck to an old instance
callahero
Hi all, I have a AWS Lightsail instance of 3cx that ran fine for a couple years. I had some issues one day that prompted me to want to relocate the instance to Ohio from the more issue prone DC area. I created a new AWS Lightsail instance and used the 3cx Express to install and set up my duplicate installation in the new instance. Once this was done, i notified my SIP provider to add the new static IP to my system and after a backup restore, i was up and running. A few weeks go by and i started to see calls not coming through. Now it seems that if i ping my FQDN it resolves to the old instance IP address, not the new one that the 3CX Express created. I can get into both installations, one with the FQDN and the new one in the Ohio server farm with the IP. I would like my FQDN corrected and i am willing to delete the old AWS instance. Any suggestions are appreciated. Thanks in advance!
Please first delete (or at least shut down) the old instance, THEN switch new instance network to "dynamic IP", wait a minute, then check that it took ip into account, then get back to static IP. Should make the trick !
Thanks Innotip! That did the trick, i saw that you had recommended this to someone else and i tried it but did not stop the old instance first. now that i did, all worked as expected. Thank you!
3K8iMGWviZ
