Solved Fresh Installation
texmansru47
SOHO User
So I was told on here that my initial installation was WRONG or BAD since I could not get two FANVIL X3S phones with the proper firmware to work... So I uninstalled my 3CX installation on the Raspberry Pi 4B I have (64GB of RAM) (same server) and did a fresh installation..... Well everything when great UNTIL!!!!!!!! The http://ip_address:5015 part... The server is REFUSING MY CONNECTION. I swear it is always something with this software. I am going to rebuild the raspberry pi YET AGAIN to see if that resolves the issue. This is my last shot at this software BTW there is NO FIREWALL or PROXY preventing the port 5015 from being loaded. It is like the installation failed... and I used the one from your page.
Is this install on Windows or Debian?
When you go to the http://ip_address:5015 are you also adding ?v=2 to the end? I.E. http://ip_address:5015?v=2
It does require the ?v=2 to load.
I realize now if it is a raspberry pi you probably meant it has a 64 GB SD card for storage.
I asked if it was Windows or Debian because I saw 64 GB of RAM and assumed the raspberry pi was acting as a SBC connected to the PBX.
I had this 3 times when installing on a windows 10 vm. You need to just run the install again. IF you just get login screen after install then it's bad. I think It might have something to do with the fqdn during install.
It was Raspbian and I got it to work finally
mazet
