Solved Galaxy S10e Echo Issues
3C Technology
Platinum Partner
Hi Guys
I have a Samsung galaxy S10e (SM-G970F)
Software version Android 9 (G970FXXU3ASIE)
3cx App Version 16.2.0.30 and also on the earlier beta builds
After installing the 3cx client and testing calls they work perfectly without any echo.
However after a few days of use i start to receive complaints of my call echoing to
the caller. Changing the echo cancelation setting to off and back on makes no
difference deleting the account and re-adding has no effect. If i remove the 3cx
app and re-download and reconfigure it works perfectly again.
Cheers
Can you try to toggle the option Advanced > Car / bluetooth support (Telecom API) and see if this helps you?
Hi John
Funily enough i had changed that on monday when i reinstalled the app and have yet to have the echo issue return. I will monitor for a few more days and then reenable it to see if issue returns
and provide feedback.
Cheers
Reactions: JohnS_3CX
Good hear, just keep in mind that different telephony APIs and different models handle echo cancellation in their own way, so we include both methods.
Hi @JohnS_3CX
Ok confirmed that the setting Advanced > Car / bluetooth support (Telecom API) is the cause of the echo when enabled..
Cheers
Finatra.us
