Galaxy S9 Android App Issue
jonpwatson5
Phone: Samsung Galaxy S9 (SM-G960F)
Android Version: 9
Baseband Version: G960FXXS3CSD2
Build Number: PPR1.180610.011.G960FXXS3CSD1
Android security patch level: 1 April 2019
3CX App Version: 16.0.0.35 (also same issue with 16.0.0.47)
3CX System Version: 15.5.155202.6
Calls aren't coming through to my Android app, they are only ringing on the desk phone. If I open the app it says registering, so it's obviously not keeping the app running - I've checked the settings for the app and it isn't set to optimise battery usage.
I can see on the event log when I open the Android app it shows it as registered, but then if I come out of the app and leave it to run in the background the eventlog shows it as becoming unregistered. Firebase push is setup.107741077510777
Any ideas? Thanks.
Sorry i'm french, so english is ok but Russiano_O
i've tried with success on several Android phones also from 6.01 , 7 and 8 on Samsung S8, Lenovo P2, Samsung S4.
All needed to change settings for power saving mode, but for now they do the job.
My pbx is cloud based Debian V16.273
[/ QUOTE]
Now the translator in the Chrome browser solves everything, I'm from Ukraine, but this is not a problem for communication on the English-language forum, in general, telephony on 3cx is simply super, I set everything up and figured it all out in a fairly short time (about 2 weeks, considering that a programmer and not a sysadmin) the problem with a call on Android phones is the last one that I can’t solve for more than a week trying to solve, but without result.
[QUOTE = "aws2p, сообщение: 283647, участник: 60031"]
Я пытался с успехом на нескольких телефонах Android также с 6.01, 7 и 8 на Samsung S8, Lenovo P2, Samsung S4.
Все, что нужно для изменения настроек режима энергосбережения, но пока они делают свою работу.
Мой pbx основан на облаке Debian V16.273
[/ QUOTE]
My system is installed on windows server 2012, maybe there is a problem in this installation package.
Energy saving and traffic saving for 3cx is turned off on all phones.
do you almost receive notifications for missed calls ?
for me it was only what i got when power save settings weren't changed, since it was done everything was working fine.
Your Pbx is local on dedicated Server 2012?
i've a cloud demo pbx do you want i create an extension to test with your phones
notification of a missed call on android smartphones when impeded due to the falling of the system, the delay did not always occur in sleep mode, mainly when unlocking the phone
I do not understand what you mean, what would I give you the IP address of the server? For testing from Google?
Or do you propose to register for testing one of the smartphones on your server? and also one of your trunks? I think it is not quite safe ....
if problem is occuring on your pbx , trying connection from another may be interesting almost to see if phones are part of the problem or not.
Yes, i create an extension just to test from a demo pbx not in production, so if i send you the QR code you can register on Android and then we can try to call each on internal extensions to see if your phone is working properly or not. that's all, no trunk needed for this , after call test, extension is deleted
Let's try on Monday, now there is no possibility. I expect a barcode from you, as well as contacts to telegrams or vibers for more quick communication when checking, Thank you.
Hi ,
can you send me via PM a mail adress i can send you a welcome email.
For monday trying, it will be possible for me at 14h00.
It seems that I solved the problem with push notifications on android, the essence of the problem on my part, the business is that there are two instructions for setting up notifications, one is in the android market, and the second is by reference in the web interface of the 3cx server, by reference to the account push . The one that leads to the API setting through Google project does not give me a result, but the one that earned the fire project, the link below https://www.3cx.com/docs/ maybe someone come in handy. aws2p thank you for your support and testing and your time!
Reactions: AWS2P
Mahlon
