GDS3710 and 3CX?
Randall Caudill
Does the Grandstream GDS3710 work with 3CX?
It appears to be a SIP device, so it should work, however, it also handles video, which may be an issue. I assume that there is no 3CX template for that model. That being the case you should probably approach Grandsteam (or their forum). as the have supplied templates in the past. They may have tested the model with 3CX, and have some suggestions. Someone on the 3CX forum may also have some experience with the device.
Yeah that's what I was thinking.... but I will reach out to Grandstream and see what I can find.
Thanks for the reply!
Any luck finding a solution? I have the same situation.
megalmazan
