Generating CDRs
novatel
If it's possible 3CX phone system to generate CDRs just for outbound calls?
I do not think you can, you probably have to exclude inbound / internal calls within the application importing the data.
Hello @novatel
Please note that there is no way of only exporting CDR data for a specific type of calls. You will need to sort them after the data are exported.
The CDR does explicitly state whether the call was inbound or outbound. As others have suggested, just ignore the calls you don't want.
gmacinit
