Generating config file for system setup
iduncan
Hi folks, I am wondering if this is just a bug, or if someone could enlighten me as to what I did wrong. I reinstalled the Debian version of 3cx on one of our systems yesterday as it was running on the beta version for testing purposes. The reinstall was to prepare it for live service. During the setup, it asked me to either restore a backup, or generate a config file from https://www.3cx.com/install, however, when I go there, it just redirects to 3cx.com/try. Is this intentional? What is the process if i need to reinstall a system with no backup? I managed a workaround by just modifying an older config file, and adjusted it with the correct license key, and some other minor adjustments so the pbx is running normally again.
Go to your partner/customer portal, open the license and click INSTALL top-right, use the "On-Premise" option and follow the steps. At the end, copy the URL and put that in the setup wizard.
Reactions: KyriacosS_3CX
ARKC
