Solved get agent status report
m.jeu
we already have a report which shows at which time an agent logged in and when he/she logged out. Is there also a way to get the time they have been on available?
Use case: Calls are moved to the overflow queue due missing agents being available even there should be enough people at shift.
Best,
Matthias
Hi @m.jeu,
There isn't a report to show how many hours an agent has been available. Also, if there was one, it wouldn't help to show you why this is happening because an agent can stay available but still log out of a queue which will forward the calls to the overflow queue regardless, and on the flip side an agent can be marked "away" but still receive the queue call.
The report that you have for agents logged in / logged out is exactly what you'd need.
Hi @VasilisV_3CX,
Thank you for your fast reply. Do you think that would be sth. which can be build, like setting time stamps for every status + time within queue?
Best,
Matthias
Ok - thank you.
Reactions: VasilisV_3CX
Kayla Norris
