Getting calls record generated but call journaling not working
ankit.awasthi
New User
I have integrated HubSpot and 3cx. I am getting the call record generated in the HubSpot call object but the contact call logs are not getting generated automatically. I have set up the call journaling from the 3cx side and also created the connected app according to the following documentation. What can be the possible reason?
https://www.3cx.com/docs/hubspot-pb... integration with HubSpot,the 3CX API for CRM.
What do you mean by the "call record generated" but not "call logs"?
Usually, the call record is associated to the company or contact if a match was found.
In HubSpot after making a call through 3cx: data is getting generated in calls object of HubSpot but, it is not getting reflected in the associated contacts activities(call logs)
That means the call log isn't getting associated properly I'm guessing. The thing is, it shouldn't create the call object if it didn't match a contact or something.
Can you show a screenshot of what you get in HubSpot? (Make sure to hide confidential information.)
Not getting reflected here in activities as a call log, but it is working fine in the calls object and displays call and all the details
Show a screenshot of the call record you mention that should be appearing there.
