Gold Partner License
Wetron
SMB User
Hi, I have the pro license bought from a Partner. How could I put it in my systems so it can be registered as my own. Thanks!
That is for what a partner is. They can help you to install the licence.
Admin > System > License > Replace
You would need to set it up as I can see you have an SMB license. There is no upgrade path from an SMB to a PRO dedicated. It will have to be setup as a dedicated instance.
Diogo Maia
