Solved Google Hosted 3CX Server FDQN Changes...
Erik Nathe
Good Morning!
I just want to verify there isn't anything we need to do in regards to the FDQN endpoint changes to activate.3cx.com. Out 3CX instance is already on V18 and is hosted on a Google (linux) server that was set up using the instance setup process with 3CX. I imagine that it's not restricted on what sites it can access though I could be wrong, I don't see any documentation that supports either way...
If we do need to make a change, does anyone know the steps for doing so on linux?
Hi @Erik Nathe,
If you're running the latest version of v18, there won't be anything else you need to change.
Also note that if you reployed with pbx express network config, you should be fine as well.
Hi @Erik Nathe,
Great! Thank you!
Reactions: VasilisV_3CX
Sure thing @Erik Nathe, feel free to open a new thread if you require any further assistance or information!
Bluebox Global
