Grandstream 2616 Button Mapping
Chaz
Is there a way to map the DID's onto the buttons? We want to be able to see what direct number the call is coming in on.
Thanks,
Chaz
Thanks,
Chaz
No you can't do what you say.
BUT, you can enable the "Prepend/Append DID/IVR/Queue/Ring group Name" under Advanced -> Contacts -> Options. This way, the DID inbound rule name can be prepended or appended to the CID of an incoming call.
Thanks. That should work. I will give it a try.
natedog
