Grandstream DP750 and WP820 Templates
bcarrico
Platinum Partner
I have been trying to upload a template for the DP750 and WP820 phones into the settings - templates section and it will never take it. Each time we upgrade, we're having to go manually dump the attached templates into the Templates - fxs folder on the 3CX Server. Could someone please help us get these where they can easily be imported and work correctly from the FXS/DECT page?
Reactions: Roby_M
Unfortunately, when using custom FXS templates, that's the only way. I have to re-upload them as well everytime.
Make it simple: use GDMS with a template based on the 3CX one you have. That's what I did and it's easier like this.
Reactions: bcarrico
