Solved grandstream firmware
anniesandhu
Forum User
3cx is using 1.4.0.125
where as grandstream is providing their latest firmware as 1.4.0.128
so it is conflicting
please suggest the solutions
Always use 3cx tested version - unless you have a good reason not too.
And, be sure to give more specifics when needed. Grandstream has many phones for example - The 2130/35/40/60/70 series is on 1.0.9.102. So, be sure to give model numbers and such.
sure. :)
The phone model is gxp 1620 (grandstream )
My phone has firmware as 1.4.0.106 that needs to change into 1.4.0.125
Second phone has firmware as 1.4.0.128 that needs to degrade into 1.4.0.125
because 3cx pbx management console supports only 1.4.0.125
sorry actually two threads were opened
Always update phones via 3cx server and not via grandstream firmware url as you stated
sure. :)
the newer will likely work fine... grandstrream wasn't supported at all for some time and I used them successfully managing firmware on my own.
That is really great. please help me in managing the firmware of the my phones
What method do you use to test the firmware prior to releasing to production? We have GrandStream GXP2170 phones and are currently on firmware v 1.0.9.71.
3cx has approved 1.0.9.102 on SP5 and I have not experienced any negative issues.
What kind of help do you need - just use 3cx to deploy firmware and not Grandstreams website.
but how to deploy it.I want to know the step by step procedure
if the phone has been provisioned using 3cx:
find the phone in the phone section of 3cx.
click on it. click firmware.
btw: how much of the admin manual have you reviewed?
Reactions: anniesandhu
I have tired with the same way but it is not upgrading at all
phone starts rebooting but never got upgraded
Thank you so much ever Craigreilly :)
Phones have upgraded
Best wishes
Reactions: YiannisH_3CX
Bluebox Global
