Granular permissions
brendanr
New User
Is there a way we can set additional permissions over and above what is available in the GUI?
Our marketing department would need access to be able to run call reports at will, but we would NOT want them to be able to monitor chat logs, possibly call logs (although that may be needed for reports) and recordings (which is bizarre in itself because if you leave the "can download recordings" box unticked, yes you can't hear or download the recordings, but you can delete them entirely!).
Thanks, not looking hopeful as it sounds like it was taken out for v18!
Yes, the reporting right was concatenated during the change from v16 to v18. I'm afraid not much else that you can do in this case.
Silent_Guru
