Solved Group Call forwarding broken?
tol
I need an extension setup with a forwarding (DND) of external calls to a call queue during business hours. The call queue has an inbound rule for business hours and another routing to a voice prompt for out of business hour information. So I tried different setups:
- Set the DND forwarding for external calls to the external number of the group -> can use out of office schedule but with this setup also calls to the group the extension is member of are forwarded. Is this by design???
- Set the DND forwarding for external calls to the queue extension -> no out of office hours usable of course. Group calls are not forwarded.
UserA is member of GroupA
External call to UserA -> UserA "Forward to number" of Group B -> Inbound Rule Group B OK
External call to UserA -> UserA "Forward to Extension" of Group B -> Group B No OOO usable
External call to GroupA -> UserA "Forward to number" of Group B -> Inbound Rule Group B Is Group Call forwarding by design?
External call to GroupA -> UserA "Forward to Extension" of Group B -> No forwarding As expected, but no OOO usable for direct calls (see case 2 above)
Any ideas how to setup this? Is the group call forwarding working as expected?
Tobias
Hi @tol,
When you say DND, are you referring to the Do Not Disturb status you're editing on the extension level?
Can you define what exactly you'd like to have happen? Use a call flow such as
- Call comes in, if external forward to Call Queue / Ring Group etc
Hi @VasilisV_3CX,
yes, DND ist the Do Not Disturb status of the extension.
I would like this routing:
UserA has set DND status.
Office Hours, External call to UserA -> Forwarded to GroupB
OutOfOffice Hours, External call to UserA -> Forwarded to voice announcement (or no forwarding)
Office Hours, External call to GroupA where UserA is member -> no forwarding
OutOfOffice Hours, External call to GroupA where UserA is member -> no forwarding
Hi @tol,
You should be able to accomplish this using a dummy / routing extension.
I'd suggest the following:
  1. Office Hours, External call to UserA -> Forwarded to GroupB: Route the in office hours external calls to your dummy extension.
  2. OutOfOffice Hours, External call to UserA -> Forwarded to voice announcement: Have the dummy extension route based on "If I am busy or my phone is unregistered, forward calls to:" and choose your Queue where your group members are. At the bottom, add an exception where all calls (Caller ID: *) out of office hours route to your voice announcement IVR / extension.
Hi @VasilisV_3CX,
it is working great with dummy extensions.
Thank you very much.
Reactions: VasilisV_3CX
Glad to hear it's working! If you need any further assistance, feel free to open a new thread.
devo.it
