GSM Gateway tied to 3CX in US - Verizon
princer800
Gold Partner
Any one have a Verizon GSM gateway tied into 3CX?
You are correct - I was thinking of it in a more general sense of a SIP to Wireless provider setup.So
Before spending any money on something that may be obsolete soon, check with Verizon for compatible devices. If it is a standard VoIP device, even if not "officially" supported by 3CX, it will probably work (be sure whoever you get it from has a good return policy, just in case)
Here is a link to some CDMA gateways, but the death knell is sounding for that service
https://www.voip-info.org/cdma/
I didnt suggest purchase of another unit ? simply stating which are supported with 3CX and are known to work.
I didn't say that you did, my post wasn't directed to you, merely some advice
3K8iMGWviZ
