Guidance on suitable easy cost effective hardware for GSM support in 3cx
aruneshdutta
Hello All
I am planning to have 3cx setup running in rasperry pi , I have earlier used in cloud and worked fine. I wanted to have a cheap yet effective manner to connect the 3cx with GSM support for inbund/outbound , single sim would be sufficient. I wanted to know can dongles made to work if so please suggest the best test model .I am from India
From our list of supported devices, there is one which supports GSM modules. https://www.3cx.com/voip-gateways/
Please also note that the Raspberry Pi supports only up to Version 18 Update 2, so from this point the PBX will NOT be updating to newer versions.
thanks I'll keep that in cloud as previous, which on this supports gsm modules also any way to interface gsm usb dongle to support inbound/outbound calls
We integrate with 3rd party devices that are accessible via IP address. We do not interface directly with devices on the same machine internally, so no, we do not. Only what is in the supported lists. Anything else, you are on your own to experiment.
Reactions: aruneshdutta
thanks for useful information
grahamaskew
