H.264 - Android/iOS Apps - Mobotix T25 - Not working - possible to fix through config changes?
Michael Allacher
SOHO User
Good day,
i know that the Mobotix T25 is not an officially supported doorbell but I bought those way earlier and they are not that cheap and as they are inside the wall, also not that easy to replace.
Now the doorbell supports H.264 video and I know this works with a SIP phone that supports H.264 e.g. Fanvil V65 or Yealink T58 (or even the unsupported T49G).
However, if I tried an IOS or Android app, there just is no video. I do not even get the popup to participate in a video call. I can manually click the video icon but the video is in and endless loading spinner.
The call is setup to include video from the doorbell (as mentioned it works with some SIP phones).
Any ideas on how to fix this? Should I try using one of the Fanvil V65 as router phone for the doorbell? Might it work then?
Installed version latest v18 currently. Will probably update to v20 soon t hough.
RJenkinsROCK
